HV questions
Ok, to all of the members here with some HV experience, I have some equipment and lipos here and am thinking of doing an 8s setup in my ultra gtp on road car. I have an aveox 36/24/3 1300kv motor, about the same size as a feigao l can. Esc would be a kontronik 40/10/24. And for lipos I have 2 7200 4s 12c lipos. So I would be right at the esc limit (32v) on 8s. Hopefully the batteries (84amp constant)can keep up with this setup. I would gear for 40mph. Info from Briang's calc are below. Watch think?
Differential Ratio: 3.1428 Transmission Ratio: 1 Other Ratio: 1 Spur Tooth Count: 51 Pinion Tooth Count: 14 Total Voltage: 29.6 Motor KV: 1300 Tire Diameter (inches): 4 Tire Ballooning (inches): 0 Motor Current Draw: 0 Motor coil Ω: 0 Spur/Pinion Ratio: 3.64 : 1 Total Ratio: 11.44877 : 1 Tire Circumference (inches): 12.57 inches (319.19mm) Total Motor Speed: 38480 RPM Vehicle Speed: 40 MPH (64.25km/h) Effective Speed Rate: 1.35mph/V (2.17kmh/V) Effective KV Value: 1300 Motor Torque: Amperage not specified... Final Torque: Amperage not specified... |
First thing to watch out for is that voltage rating. Is the ESC rated in volts only, or LiPo packs? A fully charged LiPo cell can be 4.2v, which would put you at 33.6v. Some ESCs tolerate higher voltage with no problem, but some go POP if you go a tenth of a volt over.
With that voltage, 84A is lots of headroom, so you've got no worries there. Sleeb |
Yeah, figured that the esc could handle it, guess that we will see. I could do 7s, I have a 3s and 4s 4000 pack. The esc is only rated at 40 amps, but at 8s would be over 1100 watts input power.
It would be better to use a Kontronik 55-10-32 instead of the 40-10-24. In Germany, many people use it without problems at peaks of 2,8kw on 10s Lipo in their Helicopters. I have also ordered one yesterday, look at the threads of othello, it works great.
The voltage on 8s Lipo should be no problem, some guys here in Germany use their Jazz 70 on 4s Lipo instead of 13v maxximum voltage and it works perfectly. The only problem could be that the motor draws to many amps when you are accelerating.
Hope this helps, sorry for my bad english :oops: |
good info BL-Power.... and about your english... Its better than lots of Americans'.
You should see some of the grammar and spelling of these kids now days. Sometimes I can't even read their posts because the entire post is one long acronym or made-up words. welcome to rc-monster. |
| All times are GMT -4. The time now is 09:49 PM. |
