-   Fastlane Machine (https://www.rc-monster.com/forum/forumdisplay.php?f=22)
-   -   FLM Hybrid bulkhead bearings (https://www.rc-monster.com/forum/showthread.php?t=8564)
Ninmaxx 11.11.2007 06:32 PM
What bearings fit in FLM's Hybrid bulkheads?
tashpop 11.11.2007 08:34 PM
i'm not sure on the exact size, but every 1/8th diff i had laying around had the correct bearing in it, so what ever they use.
Ninmaxx 11.11.2007 09:57 PM
So I'm guessing HB bearings, thanks.
Duster_360 11.11.2007 10:54 PM
8 x 16 x 5mm brgs were the correct size for a set of UE style diffs. The hybrid cases are sized for 16mm OD brgs that are 5mm thick. The other dimension depends of pinion and diff output shaft sizes. Mine were 8mm od shafts.
