FD LST Lipo Tray???
I ordered a Fine Design Lipo Tray for my LST but was wondering how you mount it. Does anyone here have any pics or recommendations? Do I reuse the mounts for the gas tank?
It didn't come with any holes drilled and no instructions, just some velcro, two screws, two spacers (1 1/4", 1 1/8"), and two nuts. Am I missing something else. http://i160.photobucket.com/albums/t...13-07_1955.jpg http://i160.photobucket.com/albums/t...13-07_1956.jpg http://i160.photobucket.com/albums/t...13-07_1959.jpg http://i160.photobucket.com/albums/t...13-07_2002.jpg |
that is how mine came to
if you want to use screws, mark it out carefully and drill, then cover the screws with the soft side of velcro double side tape may work , but will only hold up to so many crashes |
I think I'll use these two holes and then cut the tank mounts to add a little support under the tray. Good idea entjoles, I think I will also add velcro to the bottom of the tray to hold the lipo just in case the strap breaks.:smile:
http://i160.photobucket.com/albums/t...13-07_2004.jpg http://i160.photobucket.com/albums/t...13-07_1957.jpg |
looks like the way to do it, i was just looking at your truck a little closer and was thinking the same
| All times are GMT -4. The time now is 10:17 AM. |
