-   -   e-revo with tekno conversion (https://www.rc-monster.com/forum/showthread.php?t=8615)
electric 11.14.2007 11:04 PM
Just got my roller saturday. i am going to get my tekno conversion for christmas. but i need help on buying the correct electrics, correct me if i have got something wrong but i am going to use a mamba max, cc bec, feigao 9xl, and a 4S1P 5000mah truerc lipo batt. please tell if it is a good set up or bad.
http://s220.photobucket.com/albums/d...t=IMG_0940.jpg
will be putting traxxas tubes on it, had rust on the pushrods
Matthew_Armeni 11.14.2007 11:15 PM
That's the same setup that I have, and it works very well for me. It's also about the least expensive too. If you can spare some dough, a Neu motor, or Tekno's when they come out, would be better. Also, I think TrueRC is outta stock of the 5000's, and they don't quite fit the tray, a little too long. I just put some foam under them and it was fine. A better battery from True would be the 6400 4S2P or the 8000 4S2P. They can handle the amps better but also their dimension's are smaller length and width wise because they are made out of 3200 and 4000 cells, respectively. And they're not that much more, and the weight wouldn't matter because right now my Revo is little heavier on the motor side.
Everything else sounds good, although the MMM might be out by then, and their ESC/motor combo might be a good price, so I'd wait a little while before you buy anything, you won't even have the conversion for over a month!:surprised: Good luck!
electric 12.05.2007 07:13 PM
Is there a better battery that will last longer than the truerc 4s1p that could make it through the mains with out worring about finishing and like to know what are the best type of tires and wheels from proline? An do i have to have 23mm adapter from proline? and connectors on the motor, the motor comes with known and would like the ones that will connect to the mamba max.
electric 12.29.2007 12:57 PM
Finally finished evo ready to race but i am have problems with my truerc battary one of cells is not working so sending it back to truerc and hopefully sending me a new one back.
pic's of the evo http://s220.photobucket.com/albums/dd274/Electric_014/ ( yes i am using a 3 cell orion lipo in it until i get the battary back from truerc)
teknorc 12.29.2007 01:52 PM
Hi,
I'd like to check out the pics, but a password is required :). Thanks.
electric 12.29.2007 02:51 PM
sorry here it is http://s220.photobucket.com/albums/d...t=IMG_0993.jpg
offroader 12.29.2007 11:15 PM
Is there only one picture? or I'm I missing something? It's also kind of dark and small you should take close ups with more pics.:yipi:
electric 12.30.2007 09:26 PM
no, in the top corner of the page is more
also what would be a good spur gear and clutch bell will get me 35mph and up.
