-   Fastlane Machine (https://www.rc-monster.com/forum/forumdisplay.php?f=22)
-   -   Batt Strap behind strg servo ?? (https://www.rc-monster.com/forum/showthread.php?t=8665)
Duster_360 11.17.2007 07:29 PM
I just got my strg sorted out and servo mounted on the flm chassis, but now there's no room for the front attachment point for the gorilla batt strap I was planning on using. I can get screw for the strap in by itself, but need to use the rubber sided washer. Do you mount the front of the strap on the underside here??
Suspect I'm not first to have the prob - is there a good solution out there? Anyone have a nice, neat solution??
squeeforever 11.17.2007 09:26 PM
If you could post a picture of exactly what you have to work with, we might be able to help a little more.
Duster_360 11.18.2007 12:28 AM
I'm charging the canon's batt now. I'll have a pic up in the am.
Duster_360 11.18.2007 02:45 PM
Sorry for the delay - here is pic
http://i191.photobucket.com/albums/z...att_strap1.jpg
The hole to the right behind the strg servo is where batt strap is supposed to go. Obviously can't get there with the rubber sided washer used with the gorilla strap. I you use it without that washer, strap will tear. Suggestions?
squeeforever 11.18.2007 04:38 PM
Could you go from the underside?
ClodMaxx 11.18.2007 04:51 PM
even WITH the washer, the strap will tear. i had the same setup and tried gorilla crap straps, and ripped through 3 pairs before i just gave up. they'll tear where the washer presses into the strap.
back when i had the FLM chassis, i made my own straps - found some military-strength 2" velcro on ebay and wound it all the way around the frame and batts. you can go through the spaces in the frame where the batts fit.
http://pic20.picturetrail.com/VOL127.../267535648.jpg
Duster_360 11.18.2007 05:07 PM
That was the same thing I tought off, but its pretty much the same from the other side too, again due to the strg servo and mounting screws. This is a design joke - there is no way straps/washer can work and if you use the 2 speed, its the same problem on the other side too.
While I've been reading here today, I see now the gorilla straps are not that highly regarded (crap straps indeed, lol!), so I guess I'll be looking for some wide velcro like you used Clodmaxx.
I guess this means I can't rely on these for my G2R either. Another parts quest begins....
Thanks guys!
ClodMaxx 11.18.2007 05:13 PM
sent you a PM, duster.
Duster_360 11.18.2007 05:35 PM
Thanks Scott, sent you a paypal. Appreciate your doing that!
ClodMaxx 11.18.2007 05:55 PM
no problem - glad i can help out.
