ok. i want some SERIOUS advice
im building a e-revo, with a motor mount and CD custom made by MetalMan (just like his) and stock diffs. i really want to use the MM esc because my LHS still has the old one (itll run 5s!!) this rig will be about 8-8.5 lbs with batts (trueRC 4s 4000mAh packs, or 5s 4000mAh packs) id like lots of power, good availability, lightweight, and a price of under $350 or so. i am in the US, so its hard to get a plettenberg, but i like the lehner 1930/40 series alot, because of price and weight..... brians speed calc says i need a kv of around 1100-1700 with the CD instead of tranny unless i run super low gearing (it recommends the 1930/9 with 10/46 gearing! :gasp::surprised: if you know of a great motor, that i can get fairly easily, please LMK!
can you post the specifications? that's a slow turning motor with a high gearing ratio! Something must be wrong here.
specs of what?
the speedcalculator results.
Please post them.. |
Here's what I came up with:
Vehicle Weight (approx): 10 Desired top speed in MPH: 40 Differential Ratio: 2.8461538461538462 Transmission Ratio: 2.2 Additional Ratio: 1 Spur Tooth Count: 40 Pinion Tooth Count: 20 Battery Voltage: 14 Tire Diameter (inches): 6 Total Ratio: 12.52308 : 1 Tire Circumference: 18.85 inches (478.779 mm) Required Motor RPM: 28062.983 RPM Required Motor KV: 2004.499 RPM/V Good Motor Choices: BK Wanderer 9 XL (kv=1853) BK Wanderer 8 XL (kv=2084) Better Motor Choices: No motors of this class fit the parameters you entered. Best Motor Choices: Neu 1515 1y (kv=2200) Neu 1512 2.5d (kv=2000) Neu 1512 1.5y (kv=1900) LMT 1940/9 (kv=1742) LMT 1940/8 (kv=1959) LMT 1940/7 (kv=2239) Neu 1521 1.5d (kv=1860) LMT 1950/7 (kv=1867) LMT 1950/6 (kv=2178) |
12:1 FDR? that does sound rather high for a large MT type vehicle- and only 28,000rpms on 12cells. Im no expert, but that sound like an under powered & overgeared setup... I could be wrong though.
Yeah, I think that FDR is abit high too. Also, look at the total motor speed in MM's post; 28k rpm. You'd need to gear up pretty high to get the speed you want with that motor speed. I would suggest going with higher voltage or slightly higher kv motor to get rpms in the 35k range. Then you'll see you won't need such high gearing.
Well, since I own Metalman's old revo with the sliper/diff setup I may be of some help.
Now I have one issue, the motor that Mailman sent me is supposed to be a 7xl, but according to BrianG's calc and my radar tests it must be an 8xl. In any case here is the speed calc with an 8xl and 46/20 gearing: Differential Ratio: 2.8461538461538462 Transmission Ratio: 2.2 Other Ratio: 1 Spur Tooth Count: 46 Pinion Tooth Count: 20 Total Voltage: 14.8 Motor KV: 2084 Tire Diameter (inches): 5.75 Tire Ballooning (inches): 0 Motor Current Draw: 0 Motor coil Ω: 0.0073 Spur/Pinion Ratio: 2.3 : 1 Total Ratio: 14.40154 : 1 Tire Circumference (inches): 18.06 inches (458.83mm) Total Motor Speed: 30843.2 RPM Vehicle Speed: 36.64 MPH (58.85km/h) Effective Speed Rate: 2.48mph/V (3.98kmh/V) Effective KV Value: 2084 Motor Torque: Amperage not specified... Final Torque: Amperage not specified... I am currently running 40/20 gearing and while the motor stays cool, the mm is very hot, as are the 5k batts I am using. The 46/20 kept everything much cooler. The lehner 1950 may be able to handle the higher gearing better than the feigao. I have had Griffinrn mod a mm for me and I need to install it and see how it does with this combo. I also have a pair of 4000 14.8 lipos to replace my pair of 2s 5k lipos. So 8k mah compared to 5k should help with batt temps. It is a good setup and the slipper/diff make the steering very good. Also has a low CG, so it is more stable. |
Hi lincpimp
I ordered the 7XL - starluckrc may have sent me the wrong one. I think the KV rating is marked on the enbell. 2084kv for the 8XL and 2382kv for the 7XL. I never paid attention to it when I got it - I just assumed they sent me the right one. |
IIRC it is labeled as a 7xl, but I could only get 36-37mph out of it so the calc seems to think it is an 8xl. I have a 7xl in my terror, so I may swap out and try it. Not sure why the mm gets so hot and the motor stays cooler?
correct me if i am wrong, but the true RC 4000s have 40 continuous amp draw. Isn't that a little low for a setup like this.
E-revo at 8-8.5lbs:surprised: ggggggggggggoooooodd lck man
9.5 lbs is the lowest without going to extreme measures to reduce weight... and power.
Is that RTR or without the batteries? :whistle: |
The 4000mah 10C cells are pretty strong. I have several packs that I've ran in my E maxx pretty much all summer. A 6S1P 4000mah setup pushed it past 50mph several times. One of my favorite E maxx setups has been the 4S 4000mah 10C setup. Weight for both packs is like 14 ounces. Lighter is better in alot of ways. How many Amps you're going to draw from your packs really depends on motor choice, gearing and vehicle weight. 40 amps continous, 60 amp burst is respectible depending on your setup. Remember the days of Nimh? The best of them today can't beat that, especially since they're twice as heavy. The 10C choice is a good decision IMO, IF you're not running a super HOT setup that pulls 100 amps. Even then, I have some 10,000mah 7.4v Lipo packs made from 5000mah 10C cells (2S2P) that will go 100 amps continous. For HOT, High amp draw, lightweight setups, a higher "C" rating is the way to go. But for the mid stream, and low end applications, the 10C is more economical. |
| All times are GMT -4. The time now is 09:56 PM. |
