Few questions on E-Revo Conversion
What do you guys think about the Tekno conversion kit. Opinions pls.
Are there any big difference between the 8xl and 9xl motor? If I use the Tekno kit, do I need to change any gear ratio or use the stock clutch bell. Do I need to lock the 2nd speed? What other mods do I need to do? |
The 8xl will run hotter - 9XL on 4s is a good balance IMO...
I don't have the tekno kit so can't comment on the other bits - Best of luck with the build... |
I' running the FOC locked into 2nd with a 9XL and 4s. Current gearing is 20/38 and it's pretty quick. I just ordered a 24/38 setup for more speed.
I think something around 22/38 would be just about right. I'm running around a cul-de-sac on concrete with max size tires so I need taller gearing than most probably. I must admit the Revo 3.3 chassis is in another league compared to the Emaxx chassis I just took apart. |
| All times are GMT -4. The time now is 06:36 PM. |
