-   -   Mugen MbX5 spur. (https://www.rc-monster.com/forum/showthread.php?t=8928)
naftausa 12.06.2007 06:38 PM
Mugen MbX5 spur.
hi..
i'm going to covenrt my mbx5 fro Gp to Ep..
do u know if exist some plastic spur for the center diff????
i hate the sound of metal spur with the pinion....
MetalMan 12.06.2007 07:00 PM
There is no one-piece spur gear solution, but there is another way. Mugen makes an adapter plate for their diffs that allow an Ofna spur gear like this one to mount onto the diff:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBM16&P=7
I think someone mentioned that the gear will need some modifications to fit. Unfortunately I cannot find the Mugen spur gear adapter part number, but it's out there.
The normal solution is a Kyosho plastic spur gear. That doesn't work because normal 1/8 diffs have a 6mm output shaft, but Mugen diffs use a 5mm output.
As long as you use a hardened pinion, there really isn't any problem running a steel spur with a steel pinion. Many of us have had great luck doing so.
macr0w 12.06.2007 11:47 PM
Originally Posted by naftausa (Post 133647)
hi..
I'm in the same boat as you. I think I'm just going to get a hardened pinion and keep the Mugen diff on mine.
What motor mount are you going to use? :smile:
Cartwheels 12.07.2007 12:53 AM
Here is that part #MUGZMT008. This adapter is getting harder to find. Also, it takes some very minor dremeling in the holes of the Ofna spur gear to make the screws fit in the hole staight.
naftausa 12.07.2007 06:50 AM
someone have a mugen mbx5 with plastic spur??
i really hate the metel-metal sound..
i think also that the pinion will have a longer life..
must find a plastic spur.. :no::no:
Cartwheels 12.07.2007 06:25 PM
https://www.ssl-stormerhobbies.com/c...s&pn=MUGZMT008 Here is the adapter. They must be doing away with it. No one seems to have it in stock anymore. This with the Ofna 51t spur is a pretty good way to go.
naftausa 12.07.2007 07:34 PM
i'll looking for a specific spur ofna model using the adapter??
glassdoctor 12.07.2007 11:49 PM
FWIW, I'm might have found something else that will work... that's all I can say at this point, after failing last time I tried to get a special item like this. If I find anything I will definitely let you know.
MetalMan 12.08.2007 01:39 AM
Look at my first post, the link to the spur gear is there.
Cain 02.01.2008 03:27 PM
I run an electric MBX5 that came with a hot bodies diff and uses the kyosho 46T spur. May be the easiest way to go.
Serum 02.01.2008 03:44 PM
The hardened pinions are good as they are, you can simple use those with the steel spurs.
glassdoctor 02.02.2008 12:02 AM
You guys want a plastic spur? Or is everyone happy with the metal-on-metal?
Are the metal gears kinda noisy???
I tried to get a shop to make a plastic CRT.5 spur but they drove me nuts and I gave up. Maybe I should try again and get a Mugen too... lol
