Driveshaft Kit needed for Extended Chassis?
driveshaft kit
The ext. chassis can be used with a stock plastic driveshaft taken from one of the axles. If you must have the metal shafts, those are the ones that I use. They fit perfectly, too. I have also used left over driveshafts from other vehicles in a pinch. The MP/Dominator front driveshaft works perfectly on the front, while the rear dogbone from an 1/8 buggy works on the rear (not as nice a fit -needs fuel tubing to help hold it in place). If you want the convenience of a kit, the SM/UE kit you linked is the one to go with.
I just orderd this kit for my ext gmaxx chassis today.
Thanks Mike for the info. |
No problem, Frank!
I may be able to get a package together that will work equally as well as the UE parts but for less money (steel vs. Ti). If I can get this done, I will post the info here.
Mike - it never ceases to amaze me - you are a plethora ( adjusts tie ) of knowledge and information.
LOL
That would be great to have an alternative to the UE stuff. |
Hey Mike,
Great idea - It would be nice to have a few options - at last! Maybe a package deal? I tried Eustace (MIP) about similar lengths that he is already producing, but no luck. I would need to do custom run ($$$) Im sure I could help you sell these :rolleyes: |
George,
I will contact you if/when I put something together. I am working a couple angles. Hopefully it will work out! |
is the ext worth the 38 bux>
and then some....
I agree. If you go with a gmaxx chassis then you have to get the extention.
Hey Guys - would you be interested in an adapter that would fit onto the trani output shaft end. The idea is that it would allow for a standard length shaft kit (like the MIPs) to fit the ext length.
I tried it with the mip kit, but it didn't fit (used the center shaft kit with an original length cvd bone). Perhaps a custom made adapter would work.
| All times are GMT -4. The time now is 06:53 AM. |
