-   -   Grind a Neu... (https://www.rc-monster.com/forum/showthread.php?t=9024)
steve050773 12.13.2007 06:27 PM
Grind a Neu...
You guys grind a flat spot on the Neu's for your pinion? Or does 5mm give enough grip surface for the set screw...
mkrusedc 12.13.2007 06:30 PM
Everybody here says grind it. I have not yet and so far no slipping.
cemetery gates 12.13.2007 06:31 PM
I ground a flat spot on mine, you really need it given the amount of torque these motors produce. I also use some locktite on the setscrew. If you do those two things you should rarely have a pinion come loose.
Bye:mdr:
steve050773 12.13.2007 06:33 PM
Yeah I know its what I should do... but I hate to touch a dremel to such a purty motor...
Its a 1506 so I might try and get away without it.... at least until a $15 pinion goes bye
tallyram 12.13.2007 06:40 PM
i never grind them, one less thing that can damage the motor! i soaked my pinions in denatured alcohol to remove all residues and once they dried picked one added small amount of locktite and haven't spun one yet! i change pinions frequently.
austinmaxx 12.13.2007 07:32 PM
If you don't grind the flat spot and your pinion slips will anything bad happen have a 1515/1y I am putting together and it scares me to grind on my 300buck motor
aqwut 12.13.2007 10:06 PM
you could possible have a nice circular ring around your shaft...just tape up the holes and file it... it's easy.. takes 30 seconds...
ClodMaxx 12.13.2007 10:44 PM
steve knows how to do it - he did a great job on the lehner i have.... haven't lost a pinion off of her yet. :party:
2FastSS4U 12.13.2007 10:47 PM
I lost 2 pinions on my 1515/2.5D before I finally broke down and ground a flat spot on my shaft, I too was scared because it's a pricey motor but it turned out great and haven't had a single problem since. Also loc-tite usually has a 24hr curing time so be sure to give it enough time to set before you bash on it Good luck.
Patrick 12.14.2007 12:10 AM
I ground the shaft on mine. I never use loctite, and the pinion doesn't come loose. I don't grind the last 1mm or 2, so if the pinion does start to come loose it shouldn't be able to slide past the ridge at the end of the shaft.
BrianG 12.14.2007 03:35 AM
I ground a flat spot on mine too, but I did have to also use lock-tite to keep the stupid grub screw from coming out. But that may be because I'm using a metal pinion on a metal spur.
Aragon 12.14.2007 05:06 AM
I'm another flat spot grinder and loctiter. :D
nl12 12.14.2007 08:37 AM
I wouldnt run it without the flatspot
Matthew_Armeni 12.14.2007 12:43 PM
I don't understand why they just don't come with a flat spot from the factory. It would be easier on us, and then there wouldn't be any warranty issues to deal with. How much more would it cost them?
@ nl12- You're in Pensacola? I was stationed there about 4 years ago. Do they still have the red clay off-road track by the mall? I know they got a nice asphalt on-road track setup as I was leaving. I have some pics of us running out there, I'll try to track them down.
dadgummit 12.14.2007 01:00 PM
I ground flat spots on both of my Neu's but I don't use locktite anymore. Every time I use locktite on grub screws I end up breaking off the tip of the hex driver in the grub, It is a total pain using a Dremel cut off wheel to remove the pinion gear.
