Can this be done????
Hello Everyone,
New to this forum!! I have a project under way and I need some help!!! I am setting up a brushless IGT which runs on a Kyosho 7.5 buggy chassis. I want to go 6S on the car and I have a Quark 125. I have read throughout the forum that the Quark is iffy on 6S. I plan on running a Mega Car8+ which is about 1400kv or so. I would like to also run it with mech brakes. Now, ideally, I wanted to run something like a CC HV110. I know the boat guys have done this using a Pistix adapter for pistol radios to work with airplane ESC's, but they don't use brakes!! SOOO, would I be able to run a CC HV110 with a Pistix adapter AND still have mechanical brakes?? Any help will be greatly appreciated!!! Luis |
Yes, just install a servo y harness between the receiver and the pixstic and run the brake servo off the other end of the y harness.
Or a 3 channel Rx/Tx with the 3rd channel being the brake servo. Thats how I do it.
I thought about this, but then you don't have proportional brake. It's either all or nothing!! |
Some people have reported no issues with the Quark on 6s, while others do. IIRC, the people with no problems either run mechanical brakes and/or add a couple of capacitors to the input battery leads close to the ESC case.
Thanks for the input guys!!
I've used my quark on 6s a few times. It just worked normally, no issues at all. The first 2 times I used it were in my e-maxx geared for ~50mph on grass. I haven't done any mods to it, and I don't use mechanical brakes. I wasn't slamming the brakes on all the time though.
How fast are you trying to go? What sort of driving are you going to do? |
I am going to try the Quark and see if I get what I want. If it works, great!! If not, then the CC HV will be my next step! |
| All times are GMT -4. The time now is 09:36 PM. |
