-   -   would this be a good setup for my revo? (info/screenshot) (https://www.rc-monster.com/forum/showthread.php?t=9087)
BL_RV0 12.19.2007 11:13 AM
Hi, would this work in my revo?
5s lipo
lehner 1930/9
kontronik jazz 80-6-18
~8lb truck (battery incl)
EDIT: tire diameter so small because im using komodo dragon tires.
http://i160.photobucket.com/albums/t...creenshot2.jpg
zeropointbug 12.19.2007 12:19 PM
I would be a great setup...only thing is, you can't buy Lehners at the moment. :neutral:
BrianG 12.19.2007 01:04 PM
Since you are using a decently high voltage, I would use a Neu 1512 2.5d (kv=2000) for the high end, or a 9XL as an inexpensive option. Then, just gear up a tad. To help keep the pinion size to a more manageable level, you might want to consider using the wide-ratio gear set.
By the way, you can use the "Export Values" button and copy/paste the text into the post, like this:
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.111111111111111
Additional Ratio: 1
Spur Tooth Count: 38
Pinion Tooth Count: 18
Battery Voltage: 18.5
Motor KV: 2000
Tire Diameter: 4.5
Top Speed (MPH): 39.0499 MPH
lincpimp 12.19.2007 01:05 PM
I would say go for a quark over the kontronik, just because of startup and warranty issues. If you are only going to use 5s the quark is the best, next to an mgm. I use a quark 80 with an aveox motor in my tekno revo and the combo is great, stays cool too!
BL_RV0 12.19.2007 10:11 PM
well id like to use the kon cuz no heat issues (quark) and wont kill pockets (mgm).
BL_RV0 12.19.2007 10:13 PM
fine design has em.
