Eagletree runs from the 10XL/5S Hyper 7
Finally got my new V3 eagletree (70v 150A) datalogger in the mail the other day. Hooked it up to the hyper to see what it's doing:
http://i19.tinypic.com/6q0v4g9.jpg http://i12.tinypic.com/6x91s8i.jpg 2,500w+ peaks were kinda shocking, but now I know why it's blowing up spur gears. I also now know why I can throw that car around like a rag doll: Pack voltage max: 21.1v Pack voltage min: 16.11v (this was a weird anomaly, only did this once, generally only dropped 2v under load) Pack Amps max: 152.36A (!) Pack Watts max: 2,538.32 (!!) This is with a True RC 8000mAh 10C pack. Impressive performance, that's for sure. Sleeb |
shiz dude... those TRC 8K packs are great, @135A you are over 3.4V/cell. Voltage curve looks very flat too.
wouldn't have thought the 10Xl could pull that much...makes me wonder what my 8Xl on 5S was doing, tho I don't think I was hitting the power that hard (it would just flip over otherwise) |
Im currious what my Neu 1515 1/y/f would pull on 4s in my buggy.
Which eagletree do you have? Are you using the high current adapter thing???
Mine only logs up to 120A.... yours does to 150+? |
I've got the newly-released eLogger V3...newly released as in it just shipped about a week ago or so. It handles the 150A with no add-ons, just as is. $89, but they are backordered. It only comes with wire leads, but I've found that's easier to secure than the one that had built-in Dean's plugs.
Sleeb |
| All times are GMT -4. The time now is 08:52 AM. |
