-   -   HV thermaling!!! (https://www.rc-monster.com/forum/showthread.php?t=913)
Shadow350Z 07.21.2005 06:23 PM
HV thermaling!!!
Ok i have my HV
I have 12pinion 70 spur setup as Novak suggested on theri web
but after like a 15min run it thermals
is it the hot weather here at California????
cuz i usually get 35min out of my gp3300 7cells
J Cates 07.21.2005 06:31 PM
How hot is it?
coolhandcountry 07.21.2005 07:58 PM
Is the truck running like it ussaully does? My brothers started thremoing. His brakes quit working right to. Something messed up in the system.
J Cates 07.21.2005 08:58 PM
Sounds like the best thing for you to do, is send it to Novak.
coolhandcountry 07.21.2005 09:06 PM
My bro got smart and bought an 8l feigao from mike. Went to the bk controller. Had alot more power.
Shadow350Z 07.21.2005 11:18 PM
it was like 110 outside when i was running it
Serum 07.22.2005 02:29 AM
you do have got the fan mounted on the esc?
Shadow350Z 07.22.2005 02:47 AM
yup fan on ESC
Serum 07.22.2005 02:53 AM
I personally would contact Novak with this issue. you have got the pinion/spur meshed right?
Shadow350Z 07.22.2005 03:10 AM
yeah
but i think its jus the weather here in CA
12pinion and 70spur jus as Novak suggested
when i first got the HV and ran it it wasnt hot
it was like in the 85-90s and it ran 35min or even more with the gp3300 7cells
now its freakin HOT!!!
triple digits
100-110 degrees
Serum 07.22.2005 03:14 AM
110 is absurd hot.. That is the main reason for your HV to thermal.. (i would thermal if i had to run around at 30 mph with those temps..) When you buy brushless, you should be living on the northpole.. (should be a disclaimer.. ;) )
Shadow350Z 07.22.2005 03:30 AM
Hahaha
Imagine playing tennis and basketball and running in that heat!!
I play tennis and basketball and run everyday
especially in the summer
i should get a 72spur to use espcially jus for the summer
think that stop the thermaling?
Serum 07.22.2005 03:45 AM
It is likely, though it might even get hotter as well.. (weird but true) try it, and you'll know.
hv-maxx-kid 07.22.2005 05:21 AM
I use stock gearing in the uk, on 12 cells without thermalling, must be just the climet, also have u cut out holes in the windscream, i found this helped with the motor temp.
Shadow350Z 07.22.2005 01:07 PM
windscream???
