New hi-speed project
I've done a few off-road conversions and now want something that I can hit really high speeds with (100mph+). I looked at a few electric sedan kits, but want something that is built more on a 1/8 b/truggy platform.
From what I can tell, the Ofna Ultra GTP would fit the bill. Plenty of chassis space, 2 speed, solid design etc. I was thinking of getting just the roller for now, but am thinking that getting the RTR and selling the parts I don't need (radio, engine, misc parts) might be the better way to go because it will have the body, steering/brake servos, and the 2 spd already installed. The RTR is listed as $320 and the roller is $190 at nitrohouse. I'll check a few other places first of course... Then, to get the high speeds I'm looking for; use the two speed "tranny", 6s lipo, and a Neu 1512 motor set to run around 45,000 rpm. Since I'll be using the 2 speed, I think I'll need the Tekno clutch adaptor and just set the shoe spring very loose so it grabs right away. Even though this vehicle looks to be the winner, I'm open to other ideas. One reason I like the Ofna one is the easy LHS supply. This project would get started a lot easier/faster if I could get a few hits on this first (hint hint). :yes: :wink: EDIT: Added info (more for me for future reference): Tire diameter: 4.25" F/R diff ratio: 3.1428 (44/14) Stock 2 speed spurs (2nd,1st): 45T, 49T Stock 2 speed CB (2nd,1st): 18T, 14T Optional 2 speed spurs (2nd,1st): 44T, 47T Optional 2 speed CB (2nd,1st): 21T, 17T Ugg. To get a theoretical 110mph, I'm gonna need to get the optional spur/CB set, and get a 1512/2d (kv=2600) and spin that sucker at almost 58,000 rpm. |
Good to hear that you are going for high speeds now BG. It's hard going fast in a straight line, and gets your heart pumping pretty good. What tires are you planning to use?
Welcome to the club :lol:. I'm glad I'm not alone in the chase for High Speed.
Don't know about much other than the vehicle itself. From what I've heard, a good set of foams may be the best thing to use, right? Then, mounting them so they are perfectly balanced is imperative at the speeds I'm going to try to hit.
If I can't get a 2spd spur/pinion combo right to reach those high speeds, I might have to go with a single speed and use a very large pinion. But then, I'll need a larger motor (1515 or even the 1521) to generate the low-end torque since it will be geared so high. I think I'm going to try to make the battery tray and the ESC/Rx mount out of fiberglass to keep the weight down. Should be interesting... |
The 1521 would be a nice choice. I will use the 1521/1.5Y to make my speed machine.
:gasp:A 1521 spinning at that kind of rpm would draw LOT of current. Plan for some serious battery packs and asc if you want to pull 60K rpm with a 1521!!
That RPM was based on using the max size spur/CB setup available for the 2 speed setup. I was kinda leary about those high rpms as well. If I went with a single speed setup, I wouldn't be as limited by what 2 speed gears are available and use a larger pinion and/or smaller spur. That would bring the required rpms down a bit. Heck, I could even try a direct drive setup using an outrunner, but would have no gearing options and would need to control top speed via voltage and motor choice only.
I used my 1521/1Y with 37V and that was some awesome power. Too bad the drive train didn't hold up. The six gears inside the rear diff had a little melt down. I will eventually get this http://www.vertigoperformance.com/products_Lockers.html to save my diffs.
I would not get the lockers. The will make it almost impossible to even get to high speeds. I had on in my Maxx and I couldn't hardly get about 50 with it.
i'm planning on going hv with my yosa rally project. i'll tell you my plans and maybe itll give you ideas or maybe you'll tell me im shooting myself in the foot.
pistix 12s air esc 12s a123 kb45xl motor 1000 or 1200 kv 2speed setup what ever tires will hold up i would realistically like to break 80mph with the setup, but idk if it'll do it or not. i haven't played much with the speed cal. so right now i'm clueless really. i have a kb in my very heavy emaxx running 6s2p a123 and i'm very impressed with that motor. i figured i would stick with it for this project because of price and the fact its got so much grunt. |
Sounds interesting.
You might want to play with the calc cause you'll find that you need quite tall gears, larger tires, higher voltage, higher kv motor, etc to reach those speeds. Tires are gonna be tough. I don't think anything short of using foams or solid rubber will work since it will be really high to prevent ballooning. |
Hey Brian, check this out: http://www.rc-monster.com/forum/showthread.php?t=9179
The car is very similar to the GTP in design. Plus it has a two speed! I am only trying to get to 70mph, but I can gear up if needed. You should have fun with it, my 10th scale tamiya that can do 80 is a blast, body choices will be critical, downforce and airflow management will be a big concern. |
Are you going to use a clutch, or one of mike's lst 2 pinion adapters? |
| All times are GMT -4. The time now is 03:54 AM. |
