Need some assistance from Mike on the following!!!
Hi Mike,
I have a few Lehners 22 series and I would like to know if this http://www.rc-monster.com/proddetail...orcover&cat=20 will fit them. Regards. |
The stock motor plate that you linked to is made for standard screw hole pattern motors. Lehner 19xx series, Neu 1515, 1512 Feigao L and XL, etc...
If you have a motor that has a special screw pattern I know that he has made special plates like this that can be used as "adapter" plates to fit standard motor mount screw hole configuration. I'm sure he has alrady done it for the Lehner 22xx motors so it should just be a matter of getting him to machine one up for you. Shoot him an email. I'm sure he can make some for you easy enough. |
| All times are GMT -4. The time now is 05:06 AM. |
