-   -   LSP Center Diff (https://www.rc-monster.com/forum/showthread.php?t=9340)
Blunten 01.03.2008 11:24 PM
LSP Center Diff
I'm having a problem installing a 46t kyosho spur gear onto the center diff. The spur wont go on flush with the diff case even when i try to force it in. Am I suppose to cut a piece off of the spur gear to make it fit?
Blunten
A4DTM 01.04.2008 03:17 AM
make sure you use a seal...
and it'll close when you tighten the screws..
Blunten 01.04.2008 09:12 AM
alright, thx
david lamontagn 01.04.2008 10:19 AM
Blunten
I have the same probleme when i've mine, and i've grind a little bit the diff cup with a Dremel tool and i fit perfectly.
Blunten 01.05.2008 04:21 AM
David, do you use the stock screws or do you use counter sunk screws or does it even matter.
Blunten
