-   -   fan mounting for mm esc (https://www.rc-monster.com/forum/showthread.php?t=9359)
magman 01.04.2008 11:33 PM
does anyone have any good ideas to mount the fan above the esc so it STAYS PUT?
lincpimp 01.04.2008 11:35 PM
m3 screws directly between the fins on the heatsink. Go slowly and the screw will cut its own threads. Never had a fan fall off when mounted that way. It also helps to space the fan off the heatsink 1/4" or so, helps with air flow.
magman 01.04.2008 11:49 PM
what's the best way to space off the fan?
ssspconcepts 01.04.2008 11:52 PM
Never tried it, but it seems that rubber fuel tubing cut to size would work good as spacers.
BTW...the 25mm novak fans fit perfect on the MM.
magman 01.04.2008 11:55 PM
thanks for the tips
