-   -   5s li-po w/mm esc (https://www.rc-monster.com/forum/showthread.php?t=9380)
magman 01.05.2008 07:38 PM
5s li-po w/mm esc
Anyone using a 5s w/the mm esc w/ success?
Is it capable of handling a 5s 4000mah?
jhautz 01.05.2008 08:26 PM
yes. I run 5s on the MM. The newer MMs will not handle the 5s. They simply give an overvolt error. The older ones will run 5s if you are carful with the gearing.
gixxer 01.05.2008 08:36 PM
i also run 5s with a slower (12xl) motor.
