-   -   Swollen Li-po (https://www.rc-monster.com/forum/showthread.php?t=9417)
rustnpede 01.06.2008 11:21 PM
Swollen Li-po
I have this new Li-po pack that I got almost a year ago. I havent had a chance to charge. I took it out of the box today and noticed that its swolen on one side:gasp:. Is this pack no good or can I save it?
jhautz 01.06.2008 11:28 PM
its no good. A lipo fire is not something worth chancing IMO.
rustnpede 01.06.2008 11:40 PM
What makes it swell like that?
jhautz 01.06.2008 11:49 PM
Its some sort of gas that is created when the chemistry in the cell goes bad. Dont ask me what all that is cuz I have no idea.
Cells can swell from any number of things. Physical damage, over charging, over discharging, putting more load on them than they are rated for, etc. It could be that yours went below the minumum voltage from sitting to long without getting any charge. A year is a pretty long time to not touch it. Was it charged when you stored it?
rustnpede 01.06.2008 11:56 PM
Never charged. I took it out of the mailbox, opened the packaging checked to make sure it was what I ordered, put it back in the package then stuck it on the shelf. It hasnt seen daylight since. The only charge it had was whatever it left the factory with.
Duster_360 01.07.2008 12:51 AM
I had 5 lipos swell when I was out of the country for almost 90 days. I followed every body's advice and left them half charged. Every one of them puffed the cell that was on top - 2S or 3S, it was top cell that went bad.
I was supposed to be gone only for a month, that might have been ok, but from now on, I'll store mine starting fully charged.
jhautz 01.07.2008 12:56 AM
do you have voltmeter to check the voltage of the pack?
rustnpede 01.07.2008 01:02 AM
No but I can get one. Can I safely connect it to my superbrain 989 to check the voltage without hitting the start button?
Blunten 01.07.2008 02:46 AM
you can, but you can only check the voltage on the pack not each cell
Blunten
MTBikerTim 01.07.2008 03:48 AM
I had a pack puff last night after I left it plugged into my car over night. It was already puffed a bit but this puffed up a lot.
rustnpede 01.07.2008 12:54 PM
Blunten
So im suposed to remove the shrinkwrap and test the voltage of each cell then remove the bad cell?
Originally Posted by MTBikerTim (Post 139276)
. . . It was already puffed a bit but this puffed up a lot.
How long have you been using this puffed pack? Is it common for people to continue using pack after theyve puffed. Sounds scarry to me. :eyes:
JerryF504 01.07.2008 01:05 PM
You don't have to remove the heat shrink, you can test the voltage of each cell at the balancing tap.
rustnpede 01.07.2008 01:17 PM
I understand what your saying about checking the voltage through the tap. But In the end, could I remove the bad cell and salvage the pack?
B15 01.07.2008 01:35 PM
Assuming its only one cell that went bad, yes you can save it. Ive done that with 2 different packs.
JerryF504 01.07.2008 01:58 PM
Yes, be careful when you are seperating the bad cell to not damage the good ones.
