extra long gmaxx
I have the gmaxx chassis. I have used the extension in the rear. I want to know if any one has tried to extended the front an inch as well as the rear. I am in the process of making the skid and top plate for servos.
Never tried it. The extended g-maxx is a nice length, allowing great handling without having a negative effect on the turning. I would be curious to know how it turns out, though!
I am to mike. I was just wondering if someone else may have did it. I have to let you know.
It would be easy enough to do.
1 Attachment(s)
I have assembled the front part. I just need to fix my rear and shocks so can take it out.
Well....How does it work?
I don't know yet mike. It still looks like the pic. I have not fixed my rear. Did fix shocks though. There is no gears in the rear end. I tore the teeth off the pinion shaft. Need to get them 7.5 ordered. I get it back together.
Hey cool did you get your pro3 yet, and if so whats your opinion so far?
Haven't got it yet mike d. Expect it this week. I have to get my pinion gear so i can get the truck back going. I let you know. If it survives me it is doing good. I seem to be hard on my truck.
Hey Country were did you get that alum tranny?
Jason c I sent pm. I don't want to advertise other sites on mikes. I did it once and realized what i did after. so i sent pm.
Hey Mike or any one else that may know. On the front a arms of the integy pro 3 suspension. I want to know what you supposed to use for setting up the top a arms where they mount to bulk heads. I have the group of little white washers. Is that what i am suppose to use.
On the integy pro 3 suspension. My rd logic cvd seem to short. If i take the knuckle in the turn buckle seem to long. Any suggestions.
Yes, the white spacers are for the uper arms. I use the stock black clips(easier) on mine, though. Also, the RDLogics cvds will work, but you have to turn the pillow balls in as far as you can(without binding/limiting steering/suspension movement). You will have to mess with the turnbuckle length once you get it all set up.
Thanks mike. On the turn buckles. Did you use the stock or integy ones? The integy seems to long.
| All times are GMT -4. The time now is 11:11 AM. |
