E-Revo with tekno-RC and Neu 1515/1y
Hi,
i finished a few weeks ago my revo conversion using the tenkorc kit. i used a neu 1515/1y in combination with a quark monster pro 125b. http://nitram.at/foren/revo_mounted.jpg the first runs were done with 4s Kokam H5 3200 Lipos - but with these Lipos i ran only about 10 min and had amp spikes till 70A. I was able to do wheelies with this setup ( with installed cd ) if the slipper was closed. eagletree data from the last run: http://nitram.at/foren/revo/revo_tes...1_voltage2.jpg http://nitram.at/foren/revo/revo_testfahrt1_watt.jpg I was told that the lipos will get killed with these spikes over 20C :eyes: And that the minimal voltage is about 13.12V - which i find not ok :( So i am looking for some new lipos - which would you recommend? I also want to use them in series ( as 8s setup ) in my emaxx, which i gonna rebuild this year ... |
Flightpower EVO25 and now the EVO30 was somes killers batts.
where can i purchase those evo25 and evo30 batts
thanks |
I use 14.8 volts EVO25, 5000mAh pack, and i can't tell you about run time, i don't ave the time to drain all this batt before winter. The day that my revo will be ready, lot of snow has fall outdoor, so i've to wait next summer for real test. |
hey guys, if u want hyperion 20c batteries try allerc.com they have some good deals in the clearance section (page 2) , i picked up a 4800mAh 5S 20c for 140$.
yOusef |
how do you like ur hyperion 5s 4800? Im thinking of getting this but not sure of the brand.. how does it compare to flight pwr or thunder pwr
| All times are GMT -4. The time now is 01:48 AM. |
