-   -   Neu 1515 1y (https://www.rc-monster.com/forum/showthread.php?t=9541)
DickyT 01.14.2008 10:59 AM
Neu 1515 1y
It is almost time to order the motor for my e-revo project. This Friday my wife releases the first round of 2008's RC budget to me. I want to get a Neu 1515 1Y. Mike shows out of stock on them. I have mailed him and sent a PM last week with no response asking if he would be able to hunt one down.
If anyone talks to Mike could you guys ask him about it? I really want to give RC-M my money based on previous experience.
Also will a 1515 1y/s with rc-m heatsink be the same as a 1515 1y/f? I would assume so, but figured I'd ask before I spend a good chuck of my budget.
nl12 01.14.2008 11:05 AM
The smooth can neus will not fit the RCM heatsink, they are a different diameter.
DickyT 01.14.2008 11:33 AM
Thanks, I was unaware of that. In the event I have to get a smooth can is there a heat sink that does fit them?
austinmaxx 01.14.2008 11:49 AM
I got a 1515/1y from Impakt and have one from Mike here that should be here today ...keep checking both sites and order as soon as you see it in stock ...they go fast...still waiting for the MGM controllers to come in ...order those fast too.....lol
DickyT 01.17.2008 06:56 PM
I found a smooth can 1515 1y, I will buy tomorrow when I get my round 1 budget from wife. Are there any known heat sinks that will fit or will heat on 4s and occasionally 5s geared 17/38 just not be an issue?
neweuser 01.18.2008 01:42 PM
Not sure if there are, but ask Mike to see if he can mill you one?
Just go Play 01.18.2008 02:06 PM
I run my 1515 1Y on 5s geared 16/38 and the motor has never been warm enough to worry about needing a heat sink.
neweuser 01.18.2008 02:08 PM
What do you run it in? I run mine on 5s with the REvo spur on the slipperential geat mod 1 with a 16t pinion. gets warm, but nothing to worry about as well. and that is on a 95*F day.
DickyT 01.18.2008 03:44 PM
I thought that might be the case. the main reason I spent the cash for a 1515 and did not get an 8xl or 9xl ;)
Just go Play 01.18.2008 08:45 PM
I'm running it in a 3.3 revo with the stock tranny locked in 2nd.
mkrusedc 01.18.2008 11:23 PM
Dicky looking back at my temps I don't you need anything. That was heavy bashing on 4s in an E-Maxx.
DickyT 01.18.2008 11:56 PM
that's cool. I'll accept 150 as my threshold. If it goes over that during the summer I'll worry about a cooling solution.
DickyT 01.22.2008 02:19 PM
My motor just arrived as well as the pinion and rear dust cap. My question now is do i need to get that front cover/mounting plate that Mike sells or will it be protected enough my the motor mount?
neweuser 01.22.2008 02:23 PM
You can, your motor should be fine for awhile. I however went to the hardware store and pciked up a thin sheet of aluminum and cut my own cover. It's thinner and nto as nice, but works for the purpose.
DickyT 01.22.2008 02:50 PM
If I were to buy the rc-m plate does the motor have enough shaft length to work with the rc-m motor mount and revo tranny? I drive in very dusty and sometimes sandy conditions. or mud....
