MM update is up!
saw the update for the MM at castle's web site!
http://www.castlecreations.com/downl...mamba_max.html
The update changes. Nice to see the vastly improves cogging. Interesting to hear the performance with one of cogging neus. |
I may take the Neu I run on a MGM and try it out on a MM just to see how it works now.
Mamba 25's get brushed mode too.
Yep Yep.
Did you guys download the update? How are you liking it? I downloaded and put it in my TC3 and tbh I didn't see any difference. If anyone has seen any difference please post you settings.
Last night I made a quick vid of before and after the update, with a Neu motor. The frequency of operation has definitely changed. Check it out:
http://video.google.com/videoplay?do...90454808&hl=en (make take up to an hour to become live, I just uploaded it) I have yet to install the update on the Mamba 25 in my rock crawler. It already ran the outrunner pretty well, but hopefully this will make it run even better! |
Video works for me. Yes, it does seem MUCH smoother! Nice to see it in action.
Thanks for posting this! |
It sure sounds like its smoother on the light throttle start up Metalman.
I have only one word for this!!!! FINALLY!!! |
It did cog a little in my TC3 with the N80, but when I put it in my MBX5T with 4S lipos and the Mega ACn22/30/2 it was much better then before the update. I also tried my Schulze 18.97 afterwards and the MM still can't beat the Schulze in smooth starts, but I'm impressed on how well the MM worked though. I was going to try the MM in my BPP truck with the 1521/1Y, but I couldn't find my 4mm to 5.5mm adapter, but the video posted above just proves it works good with the Neu.
I just tried this with my FLM Emaxx and a novak 6.5 I had sitting around and cogging is reduced to where this is a usable combo now. Previously cogging was so severe that the MM would over heat very quickly and required pushing the truck to get it to move.
This looks like a decent upgrade that should allow running some previously unusable motors with the MM. |
Update runs the LRP 4.5 much smoother now.
One thing I like to keep reminding myself: Castle has been doing this for about 2 years, whereas Quark and Schulze have been at it for about 8 to 10 (maybe longer?). It can certainly only get better.
glad to hear it works!!
phil |
| All times are GMT -4. The time now is 04:04 PM. |
