7.4v LiPo for receiver pack
Anyone use a 2s LiPo as a receiver pack ? I have a 2000mAh TP that I would like to use in my e-Revo for this purpose. I know the voltage is a bit high though. Do you think the servo's can take it ? There are a few voltage regulators around for this purpose, but they cost about as much as your usual BEC, so what what would be the benefit over just using a UBEC, if any ?
J. |
no benefit. just get as cheap UBEC as you can get that works with 2S lipo
Do you think radio interference may be lower with a seperate LiPo pack and voltage regulator than with a UBEC ?
J. |
Depending on the UBEC quality and how a particular rx rejects noise, there might be switching noise on the power line that could cause issues. Sometimes, simply adding a 10v 1,000uF capacitor on the UBEC output (or an unused Rx slot) can help this.
At 7.4v, there is not much benefit to a UBEC over a linear regulator. A UBEC is around 75-80% depending on design and load. If using a 3A load (worst case) and putting out 6v, minimum linear regulator efficiency will be around 76%. Not much gain there. And if you draw less than 3A, the linear regulator efficiency will be higher, while the UBEC is pretty much always at 75-80%. A linear reg loses out once the input voltage gets higher, but at 7.4v, it's a wash. You can build a linear regulator circuit (LM317T with a pass transistor and a few support components) capable of 3A or more with just a few parts available at RadioShack. Total cost could be as low as ~$10. And if you tweak the output to be closer to 6.5v, you can get it to be more efficient at closer to 85% efficient. Total size would be about that of the Koolflight BEC. |
| All times are GMT -4. The time now is 07:34 AM. |
