-   -   whats more power,bec or receiver battery running steering (https://www.rc-monster.com/forum/showthread.php?t=9705)
nitrorube 01.22.2008 12:20 PM
here is my question i will shortly be running a mamba max with a wanderer 8xl with 2 six cell nimh batteries,if i hook up a receiver pack to my steering will the motor get more power,and is there a thread on how to hook up a cc bec,thanks guys cant wait to run my emaxx,it was too slow with the stock set up for my taste,this is the best site:yipi:
BrianG 01.22.2008 12:45 PM
A BEC, UBEC, or receiver pack will not affect your main motor speed in any way. Your servo speed/power will be better with higher voltage, so a receiver pack may be the way to go since the voltage is usually at 6v or higher. Also, a receiver pack will slightly increase runtime since your main battery won't have to provide power to a BEC/UBEC, but the pack will be something else you have to charge.
As far as wiring a BEC/UBEC; it's the same as any other: Hook the input wires to your batteries and the output wires go to the battery port on your receiver. For a very basic wiring view, you can check this out - just select the BEC option you want to use...
nitrorube 01.22.2008 02:50 PM
brian man thanks alot,this is the best sight for info,fast and the answer is always right,thanks:yipi:
lincpimp 01.22.2008 03:10 PM
Yes, Brian is always right!
BrianG 01.22.2008 04:24 PM
lol, not always!
