-   -   will this fit the E? (https://www.rc-monster.com/forum/showthread.php?t=977)
Shadow350Z 08.05.2005 04:17 PM
This is a stupid question
but can this 1/5 body
http://i22.photobucket.com/albums/b3...axx/Asgard.jpg
fit the E-maxx??
if i extend the E and stuff like that
coolhandcountry 08.05.2005 05:14 PM
If you make it long enough it should work. Just have to put new holes in the body. Where do you get them from and what dimensions does that body have? I have stretched mine some. Could use a longer body.
maxxdude1234 08.05.2005 05:19 PM
There was once a guy who made a 'Quad-Motor' maxx. It had four 775 size drill motors, two trannies and was about 28 inches long and weighed 17lbs. He used a 1/5th sized buggy body on it and it looked pretty good. It can be done, but on a relatively stock sized truck, a 1/5th size body might look silly.
Shadow350Z 08.05.2005 05:24 PM
that body is a for a VS Modelsport Leopard Bettle
Length..................................720mm
Width...................................435mm
Height...................................285mm
Wheelbase............................505mm
Motor ..........Zenoah G230-04....3.9hp
coolhandcountry 08.05.2005 05:27 PM
Can some one please break that down to inches for me? I not sure how big that is. No offense there shadow. I just suck at mm. :)
maxxdude1234 08.05.2005 05:30 PM
Just divide the 'mm' figures by 25.4 to get inches.....cant be bothered working it out....:p
coolhandcountry 08.05.2005 05:50 PM
Thanks I have to remember that. Is that the truck demisions or the body.
Shadow350Z 08.05.2005 06:17 PM
those specs are for the truck the body goes on too
coolhandcountry 08.05.2005 06:44 PM
so the truck is length 28.3 width 17.4 height 11.2 wheel base 19.8
I Thinks the body will fit just fine if you stretch it some. say some where around 5 inches or so in wheel base. You would have to measure it out as you go along. You will have to make a chassis to fit you. It depends on you. You can make most any thing work.
Shadow350Z 08.05.2005 07:25 PM
yeah i wanna do it but how am I gonna extend the chassis?
coolhandcountry 08.05.2005 07:42 PM
You can take a piece of aluminum and cut it down to a lower chassis plate. I had a website that told you about it. Let me find it and i pm it to you.
Shadow350Z 08.05.2005 07:49 PM
lol ima do all this jus for that body
that body looks sweet and sleak!!
coolhandcountry 08.05.2005 07:59 PM
1 Attachment(s)
I seen a guy do a walmart hummer. It turned out good.
coolhandcountry 08.05.2005 08:02 PM
I know that is not a hummer. it is a walmart body though.
coolhandcountry 08.05.2005 08:04 PM
1 Attachment(s)
I like big trucks to. I seen some on another site.check this on out.
