LSP Conversion...
coming soon! proposed setup is
Mega aCn 22/30/2F Quark 80 Flightpower 5s 25c Lipo Gearing: 15/50 here is the data: Differential Ratio: 4.3 Transmission Ratio: 1 Other Ratio: 1 Spur Tooth Count: 50 Pinion Tooth Count: 15 Total Voltage: 21 Motor KV: 1770 Tire Diameter (inches): 5.7 Tire Ballooning (inches): 0 Motor Current Draw: 70 Motor coil Ω: 0 Spur/Pinion Ratio: 3.33 : 1 Total Ratio: 14.33333 : 1 Tire Circumference (inches): 17.91 inches (454.84mm) Total Motor Speed: 37170 RPM Vehicle Speed: 43.98 MPH (70.64km/h) Effective Speed Rate: 2.09mph/V (3.36kmh/V) Effective KV Value: 1770 Motor Torque: 0.28 ft-lbs Final Torque: 3.99 ft-lbs what do you guys think? |
That will be a nice conversion. The Mega is a nice motor. You can also use lower capacity packs like the 2200 or 2500mAh.
I think it sounds good. I havent tried a Mega motor yet so I'm interested to hear how it goes. I am wondering if the Quark 80 is enough for a truggy though. I have been running one in a 1/8 buggy on 5s with a Neu 1512/2.5d for a while and had no issues at all, but it seems that a truggy would be a little heavier. It just might be OK, but my first instinct is that its a little small and I would look for something a little bigger.
Cant wait to see the build photos. |
I forgot to attach a little video I made:
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/EAtcnCTdjAI&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/EAtcnCTdjAI&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object> |
Lutach= That Is crazy powerful! I was worried about you using a Shulze ESC since they catch fire until i heard you mention something about it and I laughed. Good luck and happy driving with your setup!
You are such a tease Lutach! If you mean a motor, just make sure you have a 12s capable esc with proportional brakes to offer with it! And make sure it is under 150 bucks for the motor/esc!
If you could do that you would be the man! |
nice setup lutach. is there a different mega you'd recommend? what mAh are the batts and what runtime do you get with them? when you said, "the pinion and spur are outta whack," you weren't kidding. it sounds like me stepping on a bag of potato chips. :lol:
hows this lipo look?
http://www3.towerhobbies.com/cgi-bin...?&I=LXRVZ9&P=7 |
what about this
http://www.hobbycity.com/hobbycity/s...idProduct=6236 |
| All times are GMT -4. The time now is 06:09 PM. |
