Reggy Build Setup/Parts!!!
First- for all of you who are wondering what Reggy stands for, its Revo Electric Truggy.
Motor- Mega aCn 22/35/2 ESC- Quark 65 (The Mega only needs 60A max, so this should work fine.) Battery- Flightpower 5s 2500mAh. only 2.5Ah because lutach says that'll be all I need. Differentials- E-maxx 3905 Center Diff- X1X CRT Steering- Xray XB8 Metal i'm using: Stiffeners/CD mount/motor mount: 6061 1/4" Chassis/other stuff: 7075 3mm and some carbon fiber stuff thrown in there, vantage revo wing... any input? |
I would say to step up you battery capacity, if only for longer runtime. I have a few quark 65 escs and they are good controllers. I would try to keep the reggy as light as possible. You may be suprised what the mega motor can pull in the way of amps. Especially depending on your gearing.
Well, i will gear for high 30's or low 40's. Then i will calculate it.... lets see what happens.
yeah, but its 200g heavier. since i'm only using 1 battery pack, itll help weight balance to haev the lighter pack.
| All times are GMT -4. The time now is 03:38 AM. |
