question on g 3 suspension
Hi all,new guy question.I like the looks of the g3 but I don't like the shocktowers.can you use the g3 arms with a dace t maxx tower or would that negate the whole geometry of the suspension?the reasons I dislike the towers is I have the dace towers with the meugen wing mount and I want to keep them plus I like roto start and it looks like it would be hard to use shaft start with the g 3 towers.anyway I'm sure you guys/gals can point me in the right direction,thanks much.
Good question.
I have the G3 suspension and CF Ext Chassis but I'm not sure if different towers could be used. I'm sure Mike and others will know the answer. |
no answers?I think I'm going with U.E.
Yes, different towers will work with the g3 suspension. You may not use the levers, depending on which shocks/towers are used, though, but the suspension works perfectly fine without the levers or g-maxx tower. On one truck, I use Nova Low profile towers without the levers(4 shock setup).
Welcome to the forums, as well! I can get G-maxx or UE parts, so whichever is your preference. |
| All times are GMT -4. The time now is 05:15 AM. |
