-   -   Good motor? (https://www.rc-monster.com/forum/showthread.php?t=9870)
1986camaro 01.31.2008 01:10 AM
Good motor?
e maxx with 5 cell a123 mm and this motor?
http://www.hobbycity.com/hobbycity/s...idProduct=4219
MetalMan 01.31.2008 01:13 AM
IMO, no. 36mm diameter is normal for 540 motors, and that one is 28mm in diameter. That motor with a 36mm diameter should be pretty good, though.
1986camaro 01.31.2008 01:15 AM
well I'm looking for a $ cheap motor that is in stock.
if this helps all i am doing is upgrading for a mm7700 that i have been using.
1986camaro 01.31.2008 01:53 AM
upgrading from not for a mm 7700
suicideneil 01.31.2008 09:19 PM
Something in the 2000-2300kv range, and 36mm diameter & 60-70mm length is what you want ideally. Feigao seem to only produce mtors when there is a big enough demand, so hence why they keep going out of stock quite often everywhere.
1986camaro 01.31.2008 09:24 PM
i think i might with this because its in stock.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=005
Arct1k 01.31.2008 09:33 PM
I think we have all pointed out that this is too hot - max to go with is 7XL - even this runs hot - 8XL would be better.
MetalMan 01.31.2008 09:37 PM
In terms of size and specs, that motor lineup is a lot like the Feigao XL lineup. I wonder what the quality is like on them.
1986camaro 01.31.2008 09:37 PM
where would i get one in stock?
1986camaro 01.31.2008 09:40 PM
i understand it might get hot, but i don't rod the piss out of my truck anyway, and i would be able to tell you guys about the quality.
Arct1k 01.31.2008 09:57 PM
http://www.offshoreelectrics.com/products.php?cat=42
1986camaro 01.31.2008 10:14 PM
are they in stock?
Arct1k 01.31.2008 11:17 PM
yes by the looks of it
