Power Switch Wires Came Off
Where do they go?
on the bottom of the circuit board where it sticks out of the side of the case. Best option for most is to solder the two points together. to heck the crappy switch.
Yeah I've had the switch come off also and just soldered it with no switch.
phil |
Right on top of those three wires? Those two little tabs? Which one goes where?
The switch wires go on the bottom side of the board, just between the red motor wire and the positive battery wire, opposite side of the board from the led's. Polarity is not important, it only makes or brokes the circuit. The black switch lead is closer to the red motor wire, if I remeber correctly. Both of my MM's have had the switch removed and the connections "bridged" with a bit os solder. (you can just get to the two pads for the switch wires with the MM assembled in it's case).
| All times are GMT -4. The time now is 11:54 PM. |
