Neu 1521 Mount dimensions
Does anybody know the distance between the mounting holes on the Neu 1521?
I think the can is 39mm diameter but needing to know the distance between the screw holes. Thanks, Nick. |
as far as i know it's 25mm
Thanks Serum,
I think the Feigao/Wanderer XL are 25mm too. |
yes the 1521 the same hole pattern as most other motors at 1" or 25.4mm (at least mine is) . the only difference is it uses 4mm screws rather than the standard 3mm screws. Just something to be aware of.
| All times are GMT -4. The time now is 09:47 AM. |
