-   -   Truck, Truggy, Muggy, Buggy ?????? (https://www.rc-monster.com/forum/showthread.php?t=9982)
DrKnow65 02.05.2008 02:07 AM
Sorry to need to ask what seems to be a common knowledge question, but I just havn't picked up the awnsers yet like I thought I would.
Would someone please break down for me what quantifies each as such...
Truck
Muggy
team3six 02.05.2008 02:18 AM
Truck: Truck or stadium, generally a 2WD truck of 1/10th scale
Truggy: A Truck and a Buggy put together, 4WD but with the design makeup of a buggy.
Muggy: A large scale 4WD design makeup of a buggy built like a truggy and larger than a truck.
Buggy: 4WD buggy
Haldir 02.05.2008 02:20 AM
A buggy is like a truggy but it's called a buggy, a truggy is like a buggy but it's called a truggy, a muggy is like a buggy, truggy and a truck but it's called a muggy, a truck is like a truggy but it's called a truck, but since a truggy is like a buggy, a trucks is kind a like a buggy as well. (center differential).
lincpimp 02.05.2008 02:41 AM
Ok here I go!
Truck: On this forum we are usually discussing monster truck, 10th scale or larger. It can also be any rc vehicle with a truck type body and truck sized wheels and tires.
Truggy: A truggy is basically an 1/8 scale buggy that has had its chassis lengthend and track widened. They usually run mt sized wheels and tires. They are easier to drive than a buggy and work better on rough tracks. Not as precise as a buggy
Muggy: This is a team losi vehicle that is basically a flat chassis (like a truggy) with lst2 suspension on each end. To heavy in my opinion and not as good as a lst2 due to the lack of a tranny.
Buggy: Generally this is 1/8 scale 4wd, however they make 10th scale versions too in 4wd and 2wd.
Hopefully that helps
its me 02.05.2008 02:46 AM
Truck
Muggy
Truck- depends what your looking at, a genral rule is that 1/8th scale are built beefier.
Buggy- 1/8th scale buggy are built on a 1/8th scale platform, 1/8 scale is build alot tougher then your average 1/10scale. 1/8 scale buggys have larger stronger diffs/ center diff/ and usually built for pure racing.
Truggy- basically is a 1/8th scale buggy but with a longer chassis/wider arms, and usually a different diff gear ratio to compensate for the truck tires.
Muggy- There's only one muggy and thats made by losi, a Muggy is a LST with a center diff and pan chassis.
EDIT* LOL im to late!
Sammus 02.05.2008 05:23 AM
I thought it was like this:
Buggy - was where it started, its the normal 1/8th little wheel 4wd most common off road racer you see.
Then there was monster truck racing.
In between there is a:
Truggy - like a MT/buggy cross, but closer to the buggy end
Muggy - MT/buggy cross, but closer to the MT end of the scale.
bdebde 02.05.2008 10:42 AM
Buggy and truggy are types of vehicles, Muggy is the name of a specific vehicle by Team Losi.
DrKnow65 02.05.2008 11:45 PM
Thanks guy's I feel enlightened. I guess I had the right understanding, I just wasn't hip to the muggy being a losi only thing.
So that was my "should have known" question for the week. I'll have another sooner or later.
bdebde 02.06.2008 12:45 AM
HERE have a look at mine (Muggy).
