HotnCold
HotnCold's Avatar
04.17.2007, 04:17 PM
Another thing you could try is to ( with a dremel ) cut a "V" slot in the plug - tin the wire - tin the plug and then while heating up the plug - slide the wire into the plug - the heat from a good soldering iron should be no problem - thats the way Monster Mike and I have done these plugs in the past - good luck...
Hows that "Hope and Change" working out for Ya???
