zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.17.2007, 07:32 PM
there are losses in the transmissions... but being warm is nothing to be worried about. Do you have lube or grease on the gears? I don't think there would be anything you can do minimize drive train resistance, unless you designed one yourself that was very efficient, but you won't gain much. I was just pointing out a statement that the power requirements are more than the square of the speed... more of the drag are at the tires to be honest, and you can only have so little drag their before it's not a tire anymore. (that's what a tire is... right? :027: :eek: )
You COULD attach CD's to your car and that would give more speed? :005:
