Tazz
Custom
04.19.2007, 07:56 AM
Stock out of the box they run mid to upper 30's. If you remove the stinger off the muffler it will do about 40. If you remove the guts from the stock muffler with the stinger removed it will run low to mid 40's. The kits have everything needed except radio batteries and gas. You get some spare parts extra diff oil, shock oil and grease along with 2 stroke mixing oil (enough for about .6-.7 gal.).
