IBJAMMIN
IBJAMMIN's Avatar
04.19.2007, 12:03 PM
Originally Posted by BrianG
Do you mean that you can use the Kyosho spur and Mike's mount without relocating the rear diff? That would be extremely cool!
No you still have to redrill the holes with the wider plastic spur gear your center diff is going to be about 2mm longer I moved my diff over in the chassis and relocated all 4 center diff holes to get the battery closer to the centerline and make room for a 4s later but you can get away with just relocating the rear holes in the chassis. :)
