BlackedOutREVO
04.22.2007, 01:29 PM
Originally Posted by hyperasus
Welcome to the wonderful world of the worthless pede drivetrain. Soon as you get your metal diff case you will be greatly disappointed when you shred the diff planet gears every other run. It sounds like you are running the aluminum idler gear is this correct? If so then that is you're first problem right there. That aluminum idler is almost as worthless as the stock plastic one. The problem is that soft aluminum starts to wear very very quickly and if you take a close look at it the teeth on it are very sharp in no time. Once the idlers teeth have been sharpened then it doesn't take long before it cuts all the teeth off the diff case. I bought a couple of those metal diff gears and ended up going back to plastic diff AND top gear to try and keep the idler from getting worn and sharpened. I was amazed at how fast that aluminum idler got worn out even with the stock diff and plastic(actually I should say delrin) top gear. In my experience the best thing to do is run the delrin top gear, plastic diff, and one of Mikes Hardened Steal idlers, then loosen up that slipper. You'll soon find out that the diffs planet gears are also very week. If you are running enough power to strip out the top gear or diff case(assuming your idler hasn't been sharpened up), then you are running more then enough power to shatter your planet gears and twist the almost as worthless traxxas drive axles. I know it all sounds crazy and backwards...but it is what I've found over the years of playing with my pedes and rusties. Also, don't be worried about that top delrin gear, it is a heck of a lot tougher then you'd think and it will keep your hardened steal idler in tip top shape for a long time, it also keeps things very quiet and smooth.
sorry but thats the biggest hunck of crap i have ever heard!!! i jump my pede 8ft n the air, back flips from a stand start and everything else!!! i caouldnt strip anything if i wanted to! something was wrong with ur pede or sumthing, my pede is all flm, 8 cells, mm 5700kv
thats sweet! u should get a swami wheelie bar now!
