skellyo
skellyo's Avatar
04.22.2007, 04:09 PM
Originally Posted by BP-Revo
Well, also remember you are comparing a 380 motor vs a 540 motor (though it has a 480 sized rotor). Either way, its still a larger motor. And even if the KV ratings were the same, the Mamba Max Motor would have more torque since its a 540 and could be geared higher because of it.
However, the Mamba Max motor also has more KV as well, so the Mamba Max will definitely be faster than the Feigao motor.
I disagree on the gearing issue. I think you can actually gear a 380C 6L more agressively then the MM 5700 with better results. The longer rotor, albeit maybe a tiny bit smaller diameter more than makes up for the torque...even moreso given the lower kv of the 6L.
However, for just doing speed runs, I don't think I'd buy either. I'd drop the $ for a Lehner.
FWIW, the 6L is no slouch of a motor...I'm running it real close to 50MPH in my T3 (gps verified at 47.7mph) with only using a 2S lipo. The problem I have is keeping the rolling wheelies to a minimum with all that torque.
www.skellyo.com/T3_4.WMV
