nl12
nl12's Avatar
04.28.2007, 09:43 AM
using different diffs gives you better gearing as well, you can use the lsp ring ring and pinion. You can also drop the center diff a lot lower by using the cr buggy center diff mounts if you are using the 46 or 44 spur. Mike also sells an adapter for a 51 t spur pm me if you are interested in using a 51t.
