BP-Revo
BMW M Power!
BP-Revo's Avatar
04.29.2007, 03:11 PM
AAngel, you must consider that when voltage goes up, amps goes down, given the same wattage.
100amps at 6S is a heck of alot more power than 100amps at 4S. So, higher voltage controllers don't usually need so much current rating, unless you are running a huge motor.
For most extreme brushless users, the limit is a 1515 Neu or a LMT1950, and the right KV version of that motor on anything above 4S is probably not going to draw anything near 100amps continuous.
Also, I beleive that amps rating is per phase, which means its actually alot more than 100amps. The Mamba Max is 100amps in brushless mode, but 1000amps in brushed mode.
