GriffinRU
04.29.2007, 05:48 PM
Originally Posted by AAngel
Griffin,
That is a tempting proposition. I have two MM controllers coming back from Castle. When they get back, I could send one off to you to look at. I have one particular MM that doesn't perform as well as the others and may be a candidate for upgrading. What do you think that cost might be?
Ok, let me know when ready.
Also, I beleive that amps rating is per phase, which means its actually alot more than 100amps. The Mamba Max is 100amps in brushless mode, but 1000amps in brushed mode.
1000A, I will question that but in configuration when 3 phases goes to one brush and other brush directly to battery it is possible, but where you can find batteries and brushes to handle that current continuous, unless you use winch motor and 3 Optima batteries :)
Would it be possible two wire to esc' in parallel to a motor?.... or is that just crazy talk. I was thinking connect the battery to both esc', then both esc' to a single BL motor. I'm guessing it would result in a puff of smoke & flames, but it would be interesting to try with a couple of those cheapo Bl systems you see on ebay- or try modding them both together to work as a more powerful system = experiment on them rather than a good MM...... [/crazy idea]
Do not ever try to use sensoreless ESC in parallel!
You can use brains from one and parallel output stages.
