04.29.2007, 06:04 PM
No, the front & rear lower a-arms are essentially identical- no difference in thickness or shape etc. The hybrids have the same extra support area I believe, so you would have to either remove it, or enlarge the gap so that the a-arm can fit into it, then get held in place with the hinge pin. Its a shame but its only the FLM bulks that seem to have this added support area- otherwise the new suspension will work perfectly on any maxx.
