Originally Posted by AAngel
Griffin,
What is the result of running two output stages in parallel? Would I get roughly double the voltage and current tolerances? Perhaps I should send you two MMs.
Brian correct I was also thinking about replacing output stage with something more heavy-duty, like Direct-FET or D2-Pak 7...
Custom PCB and hopefully MM can drive them, otherwise custom driver as well, which can be done with ir2101/ir2102 or simular.
