IBJAMMIN
IBJAMMIN's Avatar
04.30.2007, 03:54 AM
If your looking for info on brushless conversions you found the place here on the RC-monster forums.:017:
If your looking for a bolt in mount I would wait for Mike to get his mount and spur done if you want one now your going to have to redrill some holes in the chassis and use the Kyosho plastic spur see "Ricemans" post on doing this mod or find a hardened pinion? You can get the Mamba Max motor and ESC for around a 150 bucks I need to find that link?
http://www.pfmdistribution.com/secur...y.asp?catid=54
I found the weak spot in the front end today at my friends MX track jumping a 20ft dbl jump I broke a front camber turnbuckle I found a screw that fit and cut it down to get it going again and lawn darted it later and broke the C-hub and upper camber link.:002: If you dont want to be sidelined I would recomend getting some spare turnbuckles and plastic parts to be safe.:032:
ID:	2842   Click image for larger version
ID:	2843   Click image for larger version
