04.30.2007, 09:29 PM
That's nice to know! You can mod it and they'll still cover it - or did you mention you epoxied the FETs to the case? If you're gonna use 4 caps, get the 220uF ones because they'll be smaller and it will be easier to get soldered as close to the ESC as possible.
Oh, just a warning, you're gonna get a bigger arc when you plug in your batteries once you do that, but I'm sure you knew that...
