SilentMonster
SilentMonster's Avatar
05.01.2007, 02:25 PM
No fan on the MM. The gearing was the same at 24/44. Top speed was about the same at 57MPH. I know it's over geared but that is the only pinion I had. I'm assuming that just the 4 pole motor is just harder on the ESC. I expected the motor to heat up, not the MM. Other than the cogging issue with the Neu/MM I am really happy with the Neu. I really didn't want to have to run a fan. I built this for running a 30 min. main so I hope the sane gearing will make the MM more comfortable. I'm gonna put a temp Sensor on the MM also so I can see what's going on better.
"MAKE EM CRY"
