05.01.2007, 07:29 PM
I figured it was a bit barmy, to say the least, but it certainly is different. 12 pole motor.... and people say 4 poles cause too much RF noise. I think I have everything sussed out now though:-
low Kv rating motor + 14 to 22 volts + esc rated between 80-150 amps = 30,000rpms & happy times.
high Kv rating motor + 14.4-16.8 volts + hvmaxx type rating esc = 40,000rpms = need to gear down alot & hot electronics
lowish Kv motor + 14.4-20ish volts + quark125b or similar esc = 30,000 -35,000rpms & good setup?
