maxxdude1234
maxxdude1234's Avatar
07.06.2005, 05:34 PM
I know that you said brushless motor, but have you thought about a BIG drill motor ( 2 X 970). Check out www.kershawdesigns.com , you might change your mind.
If your still looking at a BL motor, the 7XL would have gobs of torque and if geared low enough, should be able to pull quite a bit of weight easily....
